Odd Expansion Tank
Dan Foley
Member Posts: 1,258
Dragon and Slavko replaced this boiler today in the Lake Barcroft section of Falls Church. It had this odd looking expansion tank. Photos attached. I’m curious if anyone has any information on this or how exactly it works.
It is on a single zone fin-tube baseboard system. Boiler supply and return connect to the bottom of the tank. System supply and return connect to the sides of the tank. Fill water connects to the side of the tank. Two air bleeders, one on each side.
I think the tank doubles as an air separator. The company that made it was right here in Baltimore.All Steamed Up, Inc.
Consulting0 -
It looks like there is a divider about 1/4 of the way from one end. it would do a great job of separating air in to the tank since the water would sit there almost still. probably be a good idea to insulate it.0
Only one pump on the system. I agree, there must be a divider in the tank.0
@ Ed
i left the tank in place. I’m still using it.0 -
If it is not broke don't fix .
I saw a similar tank, in Washington, IL, some years back. I believe it was made by B&G, but I am not really sure. Worked great, and as far I know, it is still haulin' the mail.0
Air was a major problem when the circulators were installed on the return..
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
