Loud bang as pipe cools
brogama
Member Posts: 12
Recently noticed that with my baseboard heat system that after the boiler shuts off and maybe 30-40minutes later there is one loud bang of a pipe. Confusing because it seems to be when the system is cooling. And, I haven’t been able to cycle the noise on and off. I believe the pump is still circulating at this time. Any ideas of where to start?
Most likely an expansion noise -- and yes, expansion works both ways (expanding when getting warm, getting shorter when cooling of). Question is, what's hanging up and where? They can be difficult to track down -- but look for anywhere the pipes are touching or hard up against something.Br. Jamie, osb
I have one of these right now. In my case I'm quite sure it's due to high tension in the vertical direction between a radiator and the main. Look for places where there is tension between different parts of your main or your main and baseboards. Just like Jamie said, it can be hard to find.
I think mine got introduced when I attempted to put a correct pitch on my main--one of my radiators does not have a proper swing joint on it and the radiator is basically holding up part of the main now. To be addressed when I get a minute hahaNJ Steam Homeowner. See my sight glass boiler videos: https://bit.ly/3sZW1el0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
