PROcrastination
HeatingHelp
Administrator Posts: 637
PROcrastination
We’re only human and most humans like to put off things until they absolutely have to be done. Here’s what some heating professionals have been putting off for tomorrow. Or next month. Or forever.
Sage advice. Thanks!0
Hard work pays off later, procrastination pays off now.0
This is an inspiring list of Holohan lyrics. Thanks so much for writing this!0
Procrastination:
why put off 'till tomorrow, ... what you can postpone indefinitely ?
I procrastinated on replacing my way oversized, inefficient and leaking/cracked boiler for 2 years, then after finally buying a new boiler, again I procrastinated on actually installing it.
And there sat my brand new boiler, indirect, and all sorts of new controls, fittings and venting for close to another year, right through the spring, summer and mild fall, right up until what was probably the coldest and windiest day of the year when the old one finally catastrophically failed, in the middle of the night
Cut to the scene where my wife enthusiastically expresses her displeasure with the current ambient temp while I'm scrambling to wire the circulator with a plug, removing the burner, and firing the boiler with a propane weed torch just to dump some heat into the house before I take a deep breath, cross my fingers and dive in to cutting tubing, nervously passing the point of no return
Several hours later came the extremely anxious flipping of the power switch and..... success ! (had an actual heating contractor out about a week later for reassurance) everything worked out, but it easily could have turned into a major disruption and expensive couple of days
Anyhow, the moral of this story is be careful on what you procrastinate about... i had it all worked out, all kinds of plans for the install, a couple days in the spring or summer, was going to re-route alot of the tubing and place new boiler in a different position than the existing... all sorts of improvements that made sense, but procrastination ruined those plans and forced a quick, just get it in and functioning install.
...btw, my "shiny brand new" (now 3 yrs old) indirect, is still sitting in the box1
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
