How much heat.....
Member Posts: 4,002
I have seen that before. That will reduce the output by more than 20% more like 70%. The only way to fix it to turn the elements. If what you don't know can't hurt you, then the guy who installed that must be invincible.
I understand that about 15% of the rating is radiant heat and 85% is convection heat. Since there is limited convection you might get a little thru those small slots. 25 to 30% of the rated output is about right.Edward F Young. Retired HVAC ContractorSpecialized in Residential Oil Burner and Hydronics1 -
Boy, does that bring back memories for me. I started up an oil boiler for a contractor about 30 years ago.
The fire looked good but the combustion test was disgusting. I couldn't figure out what was going on.......until the paint started burning off the boiler jacket. The fitter sent the cast iron clean out covers back to the shop....he didn't know what they were for.
Once we got the boiler fixed up we couldn't heat the building, yup he put all the baseboard in with the fins turned 90 deg.
Then came the chiller with the remote chiller barrel....two circuits. He crossed the circuits and burned holes through the fittings with oxy aceytelene and had the hot gas valve installed on the wrong compressor.
Same guy screwed it all up
Had my own business at the time, Made some money there1 -
Hi @Alan (California Radiant) Forbes , I'm wondering if this would be a good opportunity to do some measuring. If the inlet and outlet temps were recorded for a while, then the fins turned and measured again, it would likely show pretty clearly how much difference it makes. Measured data is useful!
Yours, Larry
ps, I'm always happy to make work for others.2 -
@Alan (California Radiant) Forbes Nice catch!!
How many are like this?0 -
It's the li'l things that gets ya, every time.0
Is that a union on the left side? Unions on both sides would make it easy to rotate.Yes, union on one side and I could put a union on the other side. Does anyone know if I can use ProPress on the thin copper they use for baseboard? It could be like an egg that doesn't break with even pressure all around.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
I don't think Propress is approved for anything thinner than M tubing. But i't's done all the time, it's been used on baseboard a lot0 -
I'd be inclined to sweat a male/female adapter or coupler on the fin tube and use propress form there.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
