Name that tool: What the heck is this?
Motorapido
Motorapido Member Posts: 307
edited January 2021 in THE MAIN WALL
Hmm. Fixed jaws. One jaw smooth. The other jaw has teeth. My guess is this is used to remove bolts with a stripped head. You push the jaw onto the bolt head and then bash the end with a hammer to bite into the bolt head. Then, after it has broken loose, you can turn the wrench, pull it back a bit, rotate the wrench, push it back to bite into the bolt head, etc. Anybody know definitively what this is? It comes from tools I inherited from my wife's great grandfather. I'll guess it dates back to the 1920s or so.
WMno57
  • Jackmartin
    Jackmartin Member Posts: 196
    This tool design is still used by Hydro linemen. Their version has serrated teeth on both sides of the jaw. The way you are supposed to use it is very simple lyou push the tool as far as you can on the nut ( usually on the cross member on the pole) and ratchet the nut tight. They have a another name the linemen use for them “ teeth chippers” if you do not push the tool firmly on the nut and keep pressure bearing down they tend to slip and clip you in the front of your teeth hence tooth chippers. A friend of mine —- now retired —- tells tales of all the dental work Manitoba Hydro had to pay for over the years, we have the best smiles of any hydro guys in Canada
  • residentialheating
    I haven't seen a Bull Dog alligator wrench in years! Thank you for sharing!
  • jumper
    jumper Member Posts: 2,247
    Didn't nuts get rounded?
    EBEBRATT-Ed Member Posts: 15,523
    I have seen those years ago. Never knew what they were. Now I do. I am sure the ones I saw ended up in the scrap pile
  • Larry Weingarten
    Larry Weingarten Member Posts: 3,293
    Hi, I like tools! Here is a photo of some. The bottom is an adjustable alligator wrench that I carry in my toolbag. It does things other tools can't, like grab rounded bolt heads and such. It's fun to see good old tools!!
    Yours, Larry
    ratio
