One Pipe Vacuum System
jrinaldi72
Member, Email Confirmation Posts: 1
I just bought a house and noticed that there is a Hoffman No 16 vacuum valve on the main but the radiators have newer conventional air vents. Is it possible to convert the original vacuum system to a non-vacuum system with no loss of efficiency of do I need to buy all new vacuum vents for the radiators?
As far as I know vacuum vents are no longer sold, so yes it basically is already converted0
If it is a one pipe system, it is very unlikely it was ever a Vacuum system.jrinaldi72 said:I just bought a house and noticed that there is a Hoffman No 16 vacuum valve on the main but the radiators have newer conventional air vents. Is it possible to convert the original vacuum system to a non-vacuum system with no loss of efficiency of do I need to buy all new vacuum vents for the radiators?
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
