How do you get this cap off?
It needs to come off to flush the return. How do you do it?
It looks like a plug. It should turn out. Try a little penetrating oil.0
It's a cap on a nipple. This this is what it looks like w/o the wrench. I've been soaking it in penetrating oil all day, the but there's no way to grab onto it.
1950's Bryant boiler in a 1-pipe steam system at 7,000 ft in northern NM, where basements are rare.0 -
Another approach. Is there any give at all? You might try undoing that union just above the T and seeing if you can move the offending pipe sideways and then up enough to get a wrench on it. But that won't work, of course, if the union won't come apart...Br. Jamie, osb
Also, try a smaller pipe wrench. One that you can lay flat enough that you can stand on the handle and push down.0
If you can do what Jamie said, then try to pry up the horizontal run and squeeze a 1x or something underneath.
Any way you look at it, you don't have much leverage.
Try to raise that cap high enough to get the wrench jaws at 6 and 9 o'clock. Use another wrench (probably stand on it) to hold back.
My back hurts just looking at it.1 -
OK, thanks @Fred , that makes sense. Is the right tool for that a reciprocal saw, or an angle grinder? If the former, any special blade needed?
@Jamie Hall, thanks, I should try your idea first. That union must come off to flip that pipe anyway.1950's Bryant boiler in a 1-pipe steam system at 7,000 ft in northern NM, where basements are rare.0 -
If you have to cut, I would use an angle grinder.Precaud said:OK, thanks @Fred , that makes sense. Is the right tool for that a reciprocal saw, or an angle grinder? If the former, any special blade needed?
@Jamie Hall, thanks, I should try your idea first. That union must come off to flip that pipe anyway.2 -
OK, thanks. I have that and the metal-cutting discs here. Trashing that cap is no big deal, it isn't going to be reused anyway. It will be replaced with a reducer and hose fitting for future flushing.1950's Bryant boiler in a 1-pipe steam system at 7,000 ft in northern NM, where basements are rare.0
@Larry Weingarten has it right an offset wrench. Maybe you can borrow or rent one. Or just slice the cap with an angle grinder and get it off0
10" wrench with a 24" sideways on the handle???0
Hi, I'd want to get a bigger wrench to put that cheater on. (If I'm reading your question correctly) I think a 14" or 18" with a cheater would do it without risking breaking the wrench. Do you have something big, like a 36" wrench to back this up with?
Yours, Larry0 -
I removed an identical 2" cap from a tee on the equalizer today, it took a 24" wrench with 15" cheater to budge it after soaking it overnight. I doubt a 14" would do.1950's Bryant boiler in a 1-pipe steam system at 7,000 ft in northern NM, where basements are rare.0
Where was that post with the wrench that clamped on to the pipe and had a gear drive...0
I would try tightening it down to see if you can get it to move. If you can, then I would lay the wrench with the handle to the right, and jaws at 9 and 3 o'clock. It will be coming onto the fitting at an angle, but should still grip. You might be able to get it that way.
Rick0 -
Or how about a large socket set shaped for end caps, with 36" ratchet?mattmia2 said:Where was that post with the wrench that clamped on to the pipe and had a gear drive...
1950's Bryant boiler in a 1-pipe steam system at 7,000 ft in northern NM, where basements are rare.1 -
Don't think there are sockets that will fit. There is no guarantee that any wrench will get that cap off. Cut and chisel. Tried and proven.0
You will need two wrenches, if you go the wrench route. You don't want to crack anything else.0
The socket thing was a joke... wishful thinking. Most likely it will get cut off.STEAM DOCTOR said:Don't think there are sockets that will fit. There is no guarantee that any wrench will get that cap off. Cut and chisel. Tried and proven.
I'd say the original installers did not intend to have this cap so close to the floor, there's a 1.5" gap under the other end of the wet return. It looks to me like they cut the return drip pipe or the nipple below the union (which connects to the tee) too long but just used it anyway.1950's Bryant boiler in a 1-pipe steam system at 7,000 ft in northern NM, where basements are rare.0
Hire a gorilla with a strap wrench?0
chain wrench?
Was the concrete floor there when it was installed?0 -
Wrench was turning in the other direction. Not hitting wall. They might have installed with a channellock.0
I needed a day off, will have at it tomorrow, after preparing to catch the water that will flow out once the cap wall is cut through... could be dangerous while holding the angle grinder... maybe I'll break that union and suck most of the water out first.
I'd say yes. There's a patched area nearby where the old wood-fired boiler used to be.mattmia2 said:Was the concrete floor there when it was installed?
Looking at it again, that wall is sitting on the concrete and it has wood lath so it is maybe 1930's at the latest so it looks like the floor was there in the 50's0
Yep, you nailed it. The house was built in 1930.1950's Bryant boiler in a 1-pipe steam system at 7,000 ft in northern NM, where basements are rare.0
Been there done that. Try your torch, heat the cap and use the wrench.0
if you seperate the union, you might be able to offset the 2 parts, which might allow you to raise the cap off the floor.0
If your "pipe flip" idea works, that would be a very reasonable alternative, just leave it there...mattmia2 said:Or drill and tap it for a 1/2" or 3/4" npt fitting
I haven't had success separating the union yet... I need a cheater for my 24" wrench.Alan Welch said:if you seperate the union, you might be able to offset the 2 parts, which might allow you to raise the cap off the floor.
I guess I need to get a torch, my hot air gun isn't doing the job. We have a Harbor Freight here, is one of theirs good enuf for this?HomerJSmith said:Been there done that. Try your torch, heat the cap and use the wrench.
If you lift that pipe were you going to add a tee for the header drip?
Looking back at your previous pictures. You have a cast iron 45 in that header drip.
You could "crack" that by holding a 10 lb sledge against one side and wack the opposite side with a 2 lb sledge. That will crack the fitting for removal.
You could remove that union.
A cap on the threads where the 45 went into the main drip.
Then 45 down to your new tee from the drip.
You need a union in the vertical drop.
If that drip is only a drip and not the equalizer, you could reduce to even 1" IMO. easier replacement and less costs.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
