Pilot switch on VERY old boiler
abiker
Member Posts: 1
I have what appears to be an inline pilot flame sensor switch. It acts in place of a thermocouple but is wired inline (series) with the user thermostat and pipe thermostat. The magnetic gas valve opens when 24v continuity is established.
Would anyone know where to find a replacement?
That devise looks like a White Rodgers Safety pilot that is no longer made. They were a great pilot safety when they were still available. Replacement would be to convert to a thermocouple or better yet a whole new electronic ignition system. That picture looks like a conversion burner and if that is the case I would probably start looking to replace the whole boiler. As for the best replacement, the younger guys will be along shortly.0
Not something I’ve seen before. I suspect they went away because it’s not completely fail Safe.
If the rest of the appliance is ok, might be best to upgrade it to a thermocouple Pilot assembly and matching gas valve.0 -
Google White Rodgers pilot re light control. 3098-156. If that is the part.0
@abiker, what unit is this on? Make and model?All Steamed Up, Inc.
Consulting0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
