Seek Thermal!
Solid_Fuel_Man
Member Posts: 2,646
Well this is fun!
Just my first 20 min of playing
1
Wow that is cool. I have a FLIR 1, that plugs into the camera the same way , but I think that SEEK looks like a does a much better job.0
Got this on sale at Amazon for $150. Plugs into the micro USB on my phone. Very pleased for what I paid!Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
Both of these are radiant slab with throw rugs in the images. Carpet doesnt seem to have a huge insulating effect as I'd thought.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
Is the color chart on the left side fairly accurate?
When I built these 5- 4X8 test panels with different types of dry radiant I covered 1/2 with carpet the other 1/2 was just bare 3/4" AdvanTech.
The carpet, no pad, did lower the surface temperature, but it did even out the striping effect, the carpet seemed to wick away the hot spot over the plates and move it across from plate to plate.
I think wood, really any material over a plate system helps the "spread".
Pad under the carpet cost you more surface temperature and output.Bob "hot rod" Rohr
Living the hydronic dream1 -
@flat_twin yes the chart seems to be quite accurate.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
More playingServing Northern Maine HVAC & Controls. I burn wood, it smells good!0
That's pretty impressive, that price is very impressive too!
D0 -
You have found just the tip of the iceburg.
Hydronic tubes, electric heat mats, stud finder, storm vs san sewer pipes wet drywall, bad insulation, overloaded circuit breakers, bad battery connectors, bad solar panels, which wheel or pump bearing is making all that noise. The list just goes on and on."If you can't explain it simply, you don't understand it well enough"
Albert Einstein1
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
