Recessed floor heat emitters
Simply Rad
Simply Rad Member Posts: 184
I looked at a home built in 1990. The house was remodeled and the Entrane 2 radiant floor was abandoned. The remodel was form over function and the radiant floor replacement is incredibly undersized using radiators where ever they could. Problem is there is no wall space for radiators, as the windows sit about 12" above the floor. Need a lot of heat output, as there is a lot of glass. I have used Myson floor heaters and they work great. But I need a much larger heat emitter-10-15K btus. at hopefully 140F SWT. Any ideas would help
Regards Jeffrey
Jeffrey Campbell
