speaking of concrete
hot_rod
Member Posts: 22,158
https://www.facilitiesnet.com/windowsexteriorwalls/tip/Concrete-That-Sheds-Water-Better-Than-A-Duck’s-Back--45195?source=facility_insider&utm_source=facility_insider&utm_campaign=11/26/2019&utm_medium=email
Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment1
Hydrophobic concrete has been around for sometime now. Usually saved for more ornate concrete buildings.
It definitely needs a deeper look, such as paving, and bridges in salt belts. Not for keeping a clean look, but repelling the corrosive nature of our deicing, and snow removal tactics.
Pavements usually have higher fly ash content in their mix designs. Which has a some what less porous nature.
Airport ramps, taxi ways, and runways have mix designs that helps curb the corrosive deicing agents and snow removal chemicals.0 -
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
