Tekmar 561 Thermostat
abro42
Member Posts: 12
What terminals should I connect my thermostat wires to in the TEKMAR 561 thermostat? No problems with 24 VAC input and sensor terminals but don't see terminals for my 2-wires that connected to old Honeywell (round) thermostat. I like the WI-FI capability of this TS so decided to upgrade. Is there another TT that I should be considering that is better? Trying to control 1-zone in my radiant heating system, will expand to a 2nd zone after connecting initial TT and testing it for WI-FI access and control of temperature.
Thx ...you guys really know this stuff.
Do you have a Tekmar zone control too? Otherwise it won't work. Also requires you to pull 8 wire conductor (4 for sensors).
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
