Caleffi 280 thermomix
TimZ
Member Posts: 18
Hi. I purchased a caleffi 280 thermomix last winter that came with a 130 degree sensor cartridge. The temp on the boiler runs up to 130 and then fluctuates between 127-130 for a long time as the system water trickles in. It was suggested to me that a 140 degree cartridge may be safer for boiler protection so I purchased one from supplyhouse.com. Now it runs up to 153 and fluctuates between 149-153. I was expecting for it to hover around 140. Did I get a defective one or am I missing something? Thanks.
I think your ok. Sure 140° would be better.
You don't say what type of boiler. But if in the spring, you open up the chamber, or check the flue pipe for a conventional boiler and see signs of condensation, change the cartridge.steve0 -
It’s a Weil McClain cga-3.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
