Opinions on CPS EZ Smoke
Zman
Zman Member Posts: 7,611
Recently, I have had quite a few requests to investigate sewer smells, smells from commercial kitchens entering offices and mystery water appearing in building assemblies. I hired a locate drain company to smoke the sewer lines in a complex of buildings and the results were awesome. Some leaks were found right away, others required walls to be opened and and a return trip from the company.
I got to looking at this product which is compact and has a UV dye in the smoke. The potential seems limitless. Sewer smells, HVAC diagnosis, testing vent pipe, blower door work..... http://www.thesmokemachine.com/ezsmoke/product.html
Does anyone have experience with this or similar products? For me, it really needs to be electric, compact and easy to store.
Albert Einstein
  • Ironman
    Ironman Member Posts: 7,827
    edited January 2019
    How much $$? Since it's a tool, I don't think mentioning that would violate site rules.
    Bob Boan
  • Zman
    edited January 2019
    http://www.thesmokemachine.com/ezsmoke/EZsmoke_instr.pdf
    You provide the air or inert gas. I am not sure of the requirements but I hope it would run off a small portable compressor for bigger jobs with good access or my aluminum CO2/AR welding bottle for little jobs.
    It looks like it can produce up to 5psi of pressure which could be handy for non sewer jobs.
    Albert Einstein
  • Zman
    A leaky cleanout plug and failed gasket.
    Cool tool.....
    Albert Einstein
    EBEBRATT-Ed Member Posts: 19,310
    Could see a lot of applications for that!!!
    Will probably find more leaks than we want to know about!!
