old bottom nipple connected (one pipe steam style) radiator holding condensate
cashheatandactech1
Member Posts: 10
in a building with steam supplied from a utilities connection , i have an old radiator (see pics). with a TRV installed.
it is collecting condensate (and therefore hammering). i assume it is from the trv closing , then the radiator forming a vacuum, then the radiator sucking in its own condensate and more condensate from an end of main drip trap that runs right under it (see pic).
My thought was to use another thermostatic trap as an equalizer . i was going to connect a half inch pipe from the elbow after the valve to the condensate line just before the wall. i was hoping this would equalize the ends of the radiator and allow the condensate to flow out./// This idea comes from the piping scheme that one might see on an air handler coil, to allow it to drain once the control valve has shut. This perimeter heat system is on a vacuum pump, so i can't just add a vacuum breaker.//// Does this seem like a good idea, only option, better suggestions from the gallery????????????? thanks.
here are some pics.
Have you made sure that the thermostatic trap on the drip leg of the riser drop is working correctly and closing. My first guess would be that it is the culprit. If it was leaking steam, it would do exactly what you are describing.Dave in Quad Cities, America
http://grandviewdavenport.com0 -
What you have is fine and shouldn't hammer if the traps and the trv is working correctley0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
