What Ball Valves con be used for King Valves?
krisnet55
Member Posts: 13
Im wondering if there are specific ball valves recommended for steam?
Even the HD ones are rated for 450 degrees and really high pressure. Our systems do not stress any valve out there.NJ Steam Homeowner. See my sight glass boiler videos: https://bit.ly/3sZW1el0
Anything "full port" really. It's nice to use domestic valves of course but they're likely to be used so infrequently that using an imported valve is somewhat justifiable.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes2 -
I have been a proponent of valves that have a round handle for steam use.
Ball valves have a lever handle and if they stick as they do over time, they tend to need to be forced open. When forced open, or sometimes (and often enough) the user slips the valve open to quickly forcing steam into the system. Not a good thing.
So as a habit and a safety concern, I prefer not to install ball valves on steam.
The thing is, I prefer ball valves for almost everything else1
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
