Radiator vent
ksd99
Member Posts: 77
I just took off my a1 vent to adjust the speed and there was 3 drops of water in it - is that normal?
New owner of 1 Pipe Steam Boiler - learning all I can- no real steam pro in S.W. Michigan - if you know of 1 -let me know.
Omg! why did you take it off?0
I have a Hoffman 1a and it’s hard to adjust the number with my arthritis.New owner of 1 Pipe Steam Boiler - learning all I can- no real steam pro in S.W. Michigan - if you know of 1 -let me know.0
If you think about it the steam air vent has to have steam enter it in order to close. There will always be some moisture in it from the steam.
Older air vents had a "tongue" that hung into the radiator to drain this very condensate.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
