LWCO 120volt replacement
steamer02180
Member Posts: 8
All, my boiler shut off due to a faulty LWCO. Was told it was 120V and usually they are 24V and he is trying to locate one. ARe the 120V hard to find and is an electrician needed if we put in a 24V instead. Can this be done by yourself? Any recommendations will be helpful. Located in MA and snowing now.
thanks
thanks
supplyhouse.com has 120-V models. If you want to use a 24-V LWCO, you will need an interposing relay.0
Both 24 volt and 120volt models are available at any good supply house. It's not an issue getting one0
So my old on is a Honeywell rw700a1080 120V. What would be the best replacement without having to rewire anything0
PSE-801-120 McDonnell Miller Supply House.com
That's 120 volt. There are many to choose from0 -
So looks we might have a strange one??? It’s 120volt with a 24v step down transformer in it. Anyone here of that.0
If this were my system, I'd rip out all the 120 and replace it with 24v stuff. I don't want all that line voltage running around my boiler. Anyone else feel that way?NJ Steam Homeowner. See my sight glass boiler videos: https://bit.ly/3sZW1el2
Ahh good to know. But the beauty of 24v is you don’t need that better wiring 😅NJ Steam Homeowner. See my sight glass boiler videos: https://bit.ly/3sZW1el0
@ethicalpaul
I would rather work on 120volt and up any day. Nothing wrong with 24 volt....it's the way many people install it. Sloppy, strung all over the place, loose connections etc
Because 24v cant hurt you it gets very little respect from installers and when used to wire safety controls that's not good. Those controls are important no matter which voltage they use2
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
