Steam replacement
Dave0176
Member Posts: 1,177
Dropped 248 EDR also replaced about 80 feet of wet return. EDR measured at 289 so I put in a Peerless 63-03. The old boiler was a piping disaster.
DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......
4
Looks beautiful!0
Omg that old piping was crazy!!NJ Steam Homeowner. See my sight glass boiler videos: https://bit.ly/3sZW1el0
What's funny is I am pretty sure they could have piped it correctly with less fitting than they used. Hysterical.ethicalpaul said:Omg that old piping was crazy!!
It must have been throwing water into the mains.
Hey @Dave0176 , do you ever have to check or clean out that control trap that you build? Or does it never clog like a pigtail?NJ Steam Homeowner. See my sight glass boiler videos: https://bit.ly/3sZW1el0 -
They never seem to clog however I do open them and clean them every year.ethicalpaul said:It must have been throwing water into the mains.
Hey @Dave0176 , do you ever have to check or clean out that control trap that you build? Or does it never clog like a pigtail?DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
I cannot force people to spend money, I can only suggest how to spend it wisely.......0 -
Cool, thanks, I'm sure I'll make one of these when I install my new boiler. Do you just open the plug under the pressuretrol and flush it?Dave0176 said:
They never seem to clog however I do open them and clean them every year.NJ Steam Homeowner. See my sight glass boiler videos: https://bit.ly/3sZW1el0 -
Top and bottom plug to run a brush through then the two sides to run a brush that way. Easy peasy...........ethicalpaul said:
Beats taking that stupid 1/4” pigtail off to clean that’s almost always clogged.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
I cannot force people to spend money, I can only suggest how to spend it wisely.......-1 -
I couldn’t agree more! Thanks again!NJ Steam Homeowner. See my sight glass boiler videos: https://bit.ly/3sZW1el0
New England SteamWorks
newenglandsteamworks.com0 -
Nice work, Dave.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
