How level is “Level”?
Doester
Member Posts: 17
Hi guys
Several of my radiator seem to lack slope. Attached is a picture of one sloped the wrong way(up toward vent) How much slope do I typically need? My guess is about this much is good but down away from the vent. Does “flat” usually cause problems? I don’t want to overdo it.
The vent end -- assuming one pipe steam here -- should be slightly higher than the valve end. That bubble looks pretty good, if the vent is off to the right somewhere. Maybe a little more. Certainly no less.Br. Jamie, osb
Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England-1 -
Thank you Jamie! Yes 1 pipe. I’ll shoot for shimming to that.0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
