Owner told me this Columbia bangs on startup
Steamhead
Member Posts: 16,844
Can you see why?
Consulting
Consulting
Oi vey...0
Can’t imagine why, looks perfect to me. Actually the copper could use a little polishing.3
Simply polishing wouldn't get rid of the corrosion, caused by leaking solder joints...........KC_Jones said:Can’t imagine why, looks perfect to me. Actually the copper could use a little polishing.
Consulting0 -
Lost many jobs to other contractors using copper because its "cheaper". Love the look on the homeowners face when I give them an estimate in a few years to repipe becsuse of the leaks. Mostly same two contractors doing the installs. Some people just can't seem to grasp the concept of swing joints and expansion / contraction.0
And proper pitch0
Man we’re seeing a lot of piped gems lately!! LolDL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......0 -
We'll be repiping this probably in the spring- too backed up now and with a new pigtail he's up and running. Will update when it's done.All Steamed Up, Inc.
Consulting0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
