Basement leak - elbow for return?
epic_stratton
Member Posts: 18
So first the question - is this something relatively easy for me to fix on my own? That is, could I do it in a day and with a very low chance of destroying things.
My other post dealt with a leaking vent from a baseboard radiators. Replaced those with some Hoffman 508 disc type vents. They seem to be working well enough.
But now I have a leak in the basement. Elbow of the return from the same set of radiators (elbow is off the end of the pipe that Is feeding steam (hopefully I’m getting some of this right)). Pictures hopefully help too.
Plan for the weekend was to skim the boiler due to water jumping in the sight glass but now I guess it’s this too.
Thoughts?
Thoughts?
Could this leak be from water running down the outside of the pipe, and not from a rust hole in the side?—NBC0
Nope. Definitely from the elbow or I guess possibly the adjoining piece. Not running down from anywhere though. Essentially this elbow is the bottom of a C shape connecting the steam to the return end of the system (hopefully describing that right)0
That union is sure good news for you. Still a project. My bet is the nipple is gone at the threads. Cut the close nips at the fittings and and inside the fittings and start over. Three close nipples an elbow and a union. Sawzall, little cold chisel and a hammer.Miss Hall's School service mechanic, greenhouse manager,teacher and dog walker0
There is a union right next to that elbow, that should be easy to fix.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
