Ever seen this?
bruce_21
Member Posts: 241
Customer called when he tried to shut off this valve. It broke in two and water went everywhere until he shut off the main. They have pretty bad city water and sediment. The white stuff is some rubbery silicone he put on it to stop it leaking. I soldered in a really American made valve. Note the handle name logo: "American Valve" and underneath where no one will notice it is stamped "china"
Dezincification, often caused by high levels of chlorine or other water issues. My guess. It can and has happened to pex fittings any of the earlier alloys, that were not alloyed to handle aggressive water conditions.
The epoxy repair will not help with a warranty claimBob "hot rod" Rohr
Living the hydronic dream2
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
