Not a heating problem, more like a machinist problem
EBEBRATT-Ed
Member Posts: 15,544
So I am trying to fix the depth adjustment on my Skillsaw because I can't adjust it. I had to pretty much completely disassemble the whole saw to get access to the depth adjustment knob.
After I cut the plastic knob off I am left with a threaded stud with a nut on it. Easy fix. All I need is a plastic insert nut or two nuts to lock together and I would be all set. No problem, right??
So the existing nut threads on and off the stud easily just as it should. No problem.
It looks like a 1/4-20 so I tried a 1/4-20 nut. No Good, won't thread on
It looks like a course thread but I tried a 1/4-28 fine thread nut. No Good
I tried a #12 nut. No good too small
The OD of the threads is .243-.244 with my micrometer
I went to the hardware store and got a 6mm metric nut..........too small
I also found a 7mm metric nut (which isn't even listed on most metric charts).......too big
I tried to run a 1/4-20 tap into the nut as a second check.....no good
1/4-28 tap .......no good
Again the existing nut threads on and off the stud easily... fits perfect!
I used to have some thread pitch gages gotta look for them
Skill"s website doesn't list the part separately and most parts for this saw are obsolete
Can't figure out what this is
I will probably just cut the stud off if I can and change it.
It's just such a simple thing...maybe that's why it's driving me nuts.
What else could it be??
Unlikely metric with an OD of .243 as that translates to 6.19mm.
1/4-20 is extremely common as a thread. Any chance it's an ACME thread? Common for height adjustment and distinguishable by its squared off thread.
1/4"-16 is an acme thread and would look coarse
ACME nut below for reference
https://www.mcmaster.com/94815a007
This also shows external major diameter pretty close to what you mic'd
https://westportcorp.com/blogs/thread-plug-gages/external-acme-thread-general-purpose-size-chartPeter Owens
SteamIQ1 -
@Sailah,
That's a good idea, I will try an ACME nut. Threads don't look squared off at all but it's worth a shot
Thank you0 -
Is this an actual skil saw? Worm drive, or side winder?0
Cheap sidewinder m/n 5450 I think.
And I checked not an ACME thread either...just weird0 -
got a pic?Bob "hot rod" Rohr
Living the hydronic dream0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
