Dual zone t stat?
Whats a good single t stat to connect both systems heat calls to, and where it treats them as two separate zones so i can set each one with separate temps and schedules? Ideally id like a remote wifi temp sensor for the upstairs zone because i the tstat is located on main level for summer time central air conditioning. My current setup is with two tstats where the forced air honeywell has a remote for upstsairs.
Thanks!
Since the two types of systems have such radically different needs and behaviours, I'd honestly be very surprised if any one thermostat could manage both. Consider: radiant -- no setbacks, very slow response, best with long or preferably continuous runs with output controlled by mixing valve and outdoor reset. Forced air -- doesn't mind setbacks, very rapid response, works best with frequent short cycles. Couldn't be more different if you tried.Br. Jamie, osb
If you have radiant floor heat, I would set it and forget it. Setbacks don’t work very well with floor heat, although outdoor reset does.—NBC0
Thanks guys! I plan on setting the slab and forgetting it. I am just trying to eliminate having 2 thermostats on the wall, I'd rather have one, and it would be nice if it was accessible from my mobile devices. Of course, with a single t-stat I need all the configurations I mentioned above to be possible.Jamie Hall said:Since the two types of systems have such radically different needs and behaviours, I'd honestly be very surprised if any one thermostat could manage both. Consider: radiant -- no setbacks, very slow response, best with long or preferably continuous runs with output controlled by mixing valve and outdoor reset. Forced air -- doesn't mind setbacks, very rapid response, works best with frequent short cycles. Couldn't be more different if you tried.
No question it could be done. I can't think of any company which has done it. If, however, you have a nice geeky friend all you need is several thermistors, a few ADC converter chips, an Arduino or similar computer, a wifi interface, and a few drivers and relays...Br. Jamie, osb
I can't think of anything either. Get a good WiFi stat for upstairs. If you want one downstairs, you'll need a common wire so 3 wires from stat to boiler.0
The only way I can think is a 2 stage, but I dont know of any which could do what you would like off the shelf. I'd go with two wifi stats.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
The radiant could be controlled by a stat mounted in the boiler room (closet?) with a remote sensor somewhere unobtrusive, and the forced air stat could be mounted on the main floor. A remote could be used with that one too, for that matter.
I like Honeywell RedLINK stats for wireless applications, you can get an internet gateway to allow up to 4 stats (per gateway) internet access. IIRC the Honeywell app has a demo account available.
Are you serious or is it a Flux Capacitor?0 -
And 1.21 "jig-a-watts"Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
Ok, thanks everyone, for now I'll just stick with the Tekmar slab sensor stat and the honeywell on the forced air (with remote) that I have going right now.ratio said:The radiant could be controlled by a stat mounted in the boiler room (closet?) with a remote sensor somewhere unobtrusive, and the forced air stat could be mounted on the main floor. A remote could be used with that one too, for that matter.
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
