Baseboard radiators for Steam
David_54
Member Posts: 16
Hi there. Been a while. I need to install about 9' of baseboard radiation onto a 2 pipe Trane system. Do any folks have recommendations for radiator manufacturers I should consider for the radiator, trap and related fittings? I'm familiar with Burnham, but unfamiliar with the mfgs for the other items or other radiator mfgs. Thoughts? Thanks.
Burnham baseray or Weil McLain cast iron baseboard should work fine. Just connect supply at the top plugged opening and return with trap at the bottom opening on the opposite end.0
Governdale makes GOV-BOARD which is the same as Burnham Baseray. Some supply houses may carry one but not the other- but they are the same product in the end.0
If you want to use finned tube please see Slant/Fin's finned tune selection guide and in the technical data area. We have one page dedicated on info for applying our finned tube in one and two pipe systems. If you email me at kmuhlmeister@slantfin.com I will email a pdf copy of this to you.
Just remember it is not recommended that you mix cast iron radiators with finned tube due to differences in thermal mass.
Keith Muhlmeister
Slant/Fin0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
