Down-Rating Boiler for Mouat
Harry_6
Member Posts: 141
Greetings,
I have encountered a grossly oversized boiler (must have been sized by radiator survey not taking into account the system's using larger radiators) on a Mouat system. I'm planning on having a boiler specialist come to crank it down as much as possible to get it to simmer for the Mouat system's peculiar needs, but am concerned that in some cases a boiler installer may not want to, for fear of voiding the manufacturer's warranty. This boiler is a Utica JE, but my question is not brand-specific. Your thoughts (especially you Cleveland guys).
I've got half my Mouat systems operating at 2'' wc on the gas.gwgillplumbingandheating.com
My Mouat system hits a max of about 2"WC for about 2 minutes of each of about 3 burn cycles per hour. That is a grand total of 6 minutes an hour in a pressure condition if you want to call it that. The rest of the time (90%) is it in vacuum up to 80"WC. All of it natural.1926 1000EDR Mouat 2 pipe vapor system,1957 Bryant Boiler 463,000 BTU input, Natural vacuum operation with single solenoid vent, Custom PLC control0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
