Small Burnham in6 install
gerry gill
Member Posts: 3,078
Had to keep pipes from protruding to far left due to a water heater and work bench, but had a wall to the right. So we condensed the area of the inlets to the header and the system takeoffs but oversized the heck
out of the header. Worked out very well.
gwgillplumbingandheating.com
What’s the matter @gerry gill, you break your wrists recently? It goes without saying, but awesome job.0
you mean the welded fittings? around here 4'' tee's are approaching $200 each. The Navy taught me to weld so my thoughts lately have been that i could give the money to the supply house for tee's or weld them and pay myself.gwgillplumbingandheating.com
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.1 -
just gorgeous.0
Beautiful Gerry and I'll bet you like the weight difference lifting it into place!DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......0
- 85.6K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
