Cycleguard Probe
Maine Vent
Member Posts: 130
I want to swap out the CG450 cycleguard that came on the boiler. I want a Safguard on it can I use the the CG450 probe that is in there now?
Thanks
Thanks
Weil McLean SGO4, Riello Gas Burner
404 sq ft EDR
Old Burnham V8 Removal
404 sq ft EDR
Yeah , but why not replace with the new probe that came with it ?I have enough experience to know , that I dont know it all0
Yes, no problem. With the SafGard you have to lose either the red or orange wire. I always forget which, but I think you lose the red.New England SteamWorks
newenglandsteamworks.com0 -
Thanks for the comments, probably will swap out the old probe. Since it's 5 years old.
New England I have a orange wire that is capped off and not used, the red wire looks to be connected to the water feeder.
404 sq ft EDR
Old Burnham V8 Removal0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
