The pump that you need.....
delta T
Member Posts: 884
when you find that single loop of 3/8" pex that is 4000' long buried in concrete
This pumps about 951,000 gpm and is one of several installed at a pumping station called IJmuiden in the Netherlands. Used to keep the western part of the country dry.
and actually it would not work well for the endless radiant loop application as its range of head is only up to about 16 feet.
Link where I saw this:
http://pressurewashr.com/the-worlds-most-powerful-water-pump/
This is great, the pump is use in several pumping station. Thanks for giving such a description about a pump, which is now essential in every field.
Thanks all of you
You may visit https://www.bestpressurewasherbuy.com
-3 -
Hey, I am using Sun Joe SPX3000 and it is working amazingly.-4
Gonna have to pick me one of those up! Just yesterday actually, had a DIY fella call to come look at putting a boiler in his new garage. Few weeks ago I offered to give him a bid on the tubing and he insisted on doing it himself, wanting no help. Now he's got a 1300 sq ft garage with a 1000ft roll of 1/2" in a single loop buried in the slab.0
and im sure he was happy to save 3cents on the job not realizing it will cost 1000 times that to fix, ouch!!!!!"The bitter taste of a poor install lasts far longer than the JOY of the lowest price"0
Welp, he owns a bar and talks to a million people so I will not be doing that job. Almost guaranteed the poor performance would be my fault and I'm not going to take that risk lolnewagedawn said:and im sure he was happy to save 3cents on the job not realizing it will cost 1000 times that to fix, ouch!!!!!
4 -
you are smart to walk away on a job like that, let one of the patrons from the bar do it,lol"The bitter taste of a poor install lasts far longer than the JOY of the lowest price"0
It sounds like they did, right around last callYou can have it good, fast or cheap. Pick two2 -
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
