Steam Heat Baseboard Radiator Spewing Steam
dcpalmer
Member Posts: 6
I did a quick search and didn't see anything directly on point -- forgive me if I missed it. The few posts that seemed relevant were over my head! Bottom line: When the heat came on this AM, there was steam coming out of both ends of this vent (see pic), which has holes on both sides. It was like a humidifier in the bathroom. That's not supposed to happen is it? Should I just replace the piece? What's it called?
Relevant history: You can see that dirty water has also spilled out of this. I had a neighbor putting water in the boiler while I was on vacation. He put too much (because the water guage wasn't working proporlty). Perhaps that has gunked up the works.
Any advice much appreciated. In case you can't tell, I'm no pro! Just a homeowner.
Thanks so much.
Dave
Thanks so much.
Dave
Sight glass is fine and sensor no longer gunked. Had it dealt with. I'm guessing I have to fill up a bit more than usual (but it's not bad) in part b/c of this one radiator...but I could be wrong. The boiler and everything near it is fine and relatively new. I think the only issue is the steam blowing out at this one radiator part. I'm trying to get advice so I can replace the part myself if that's possible.
Then it looks like you just need a radiator air vent......assuming this is a one pipe steam convector.
Maybe a Hoffman # 41 part number 401455.
It is described as a convector vent, non adjustable port 1/8" bottom connection. This is a straight vent, not the 90 ell design that is most common. It might be too tall for your cover.
Someone here may have a better suggestion.
If you are into DIY steam maintenance then there are some good homeowner books available. "We Got Steam Heat!" is a good starter. Then "The Lost Art of Steam Heating".
Both are a great read.-1 -
Thank you! Much appreciated. Any thoughts from others?
And: If it were up to me, I wouldn't really be in to DIY...but the price of professional help (however fair!) is inspiring. DIY is actually fun when you figure it out...ONCE you figure it out.0 -
There was a posting recently, maybe within the last 30 days, with a picture of a similar air vent.
I believe that was a water or steam air vent that closed by hydroscopic means when wet/damp. They may not have been long lived for either purpose.
Someone come up with a small steam air vent to replace it with if something like the Hoffman would not fit.
The books mentioned, are themselves inspiring and would make DIY fun and interesting.-1 -
@the_donut - I'll take some more pics this weekend and post. From what I remember, that's on the end of a single pipe...the other end is the side that comes out of the floor.0
@the_donut and anyone else:
More pics below. I can now confirm that the place that steam is coming from is the end of the single pipe, not where the pipe comes up through the floor, which is on the opposite end. You'll now see in one of the pics below. I also took one pic -- a little hard to see behind the cover -- of the other end, in case useful. In the close up of the piece I initially wrote about, you can see a small hole...that is where the steam is coming from. And there is a small hold on the other side, too, where steam also comes out (180 degrees from each other).
My central questions: Should steam be coming out of there? I know for a normal radiator the answer is no, so I'm assuming no. If not, then, should I just replace that end piece? Then, if the answer to that is yes, what is the piece? THANK YOU!
@dcpalmer, baseboard and 1-pipe steam aren’t friends, and they never will be. Baseboard isn’t designed for a 1-pipe steam system, and this is often the result. Realistically, the runout to 1-pipe steam baseboard should be upsized, and the pitch needed wouldn’t be able to be contained within the baseboard cover. Having said all that, you can try installing a new vent, possibly a straight Gorton #4.1
Is this on the first floor or second floor? Does the house have a mix of radiators? I am wondering if there is a hot water zone in your steam system. Need to see attached piping to be sure.
That fitting looks like an air bleeder for hot water. That pipe looks large enough for gravity water, hard to tell and steam pros will chime in.
If the other radiators on that line are supposed to be steam, then replace the bleeder with a slow air vent if you want heat out of that unit. If it is a water, the bleeder needs to be closed. Use gas leak detector or soapy water to figure out if the bleeder or the bushings are leaking and tighten the loose fitting.
Steam and water should never leave a properly working system. You should never have to fill the system.-1 -
Yeah. What Danny said. Get rid of the baseboard. It's not compatible with 1-pipe steam. Changing the air vent isn't going to solve the problem.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes-1 -
Thanks @Danny Scully and @JohnNY -- disappointing to hear. I had no idea. That's what was there when we bought the house...both the first floor bathroom and this second floor bathroom (@the_donut) right above it. Yes, all steam. I did find two old radiators in the garage. I wonder if they were removed from these bathrooms. Will try the Gorton and perhaps hire a pro.
Thanks all. Much appreciated. Over and out.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
