Which are the best models Pressurtrol for a residential steam system
acl10
Member Posts: 349
Which are the best models Pressurtrol for a residential steam system.
I see a few on Amazon
Honeywell PA404A1033 Pressure Trol HVAC Control
HONEYWELL PRESSURETROL MODEL L404F 1367 for steam boilers 8PSI BQ
Honeywell L404F1060 Steam Pressure
What is wrong with your current one? If it's broken just replace with a like model.0
The PA404A1033 is the standard Pressuretrol for residential boilers.0
I wanted to know which one is the best. I have a pa404a1033. I wanted to see if there is a better one out there.0
I dont know how to test mine and see if its really working0
L404F1367 would be better. If you don't know how to test your control you should call a professional. This is a safety high limit control.0
Turn the boiler on and watch the pressure gauge. If the burner cuts out at the cutin pressure + differential pressure, then you know your pressuretrol high end is good. Leave the thermostat calling for heat. The pressure will drop. If the boiler kicks back on at your cutin pressure, the pressuretrol low end works.acl10 said:I dont know how to test mine and see if its really working
What is the difference between the PA404A1033/U - and the PA404A1009
I have the 1009 on my boiler0 -
The standard ones are fine. I've seen setups using Magnehelic gauges with the internal switches. As well as various industrial pressure switches. But it's best to stick with the Honeywells, for sake of familiarity and availability.0
@acl10 , why don't you just google the control #s and find out. that's what I do.0
Wow!!.
You can't ask questions like that.
"Why don't you Google it.? Dummy."
"Mind your own business, kid."
"Don't worry about it. Jerk"
" There are no stupid questions, only stupid people."
And "Don't ask ,don't tell"
Sums it up nicely.0 -
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
