Mixing valve
cnmdesign
Member Posts: 103
Using a Taco 5000-3-G to mix water out of my DHW storage tank. Will the check valves in the mixer determine placement of the pressure tank or can I place it in the cold inlet just inside the mechanical room? Thanks
Combat Veteran owned, Final Salute LLC on FaceBook & Twitter.
www.afinalsalute.com
Steve thanks for your reply. At this time incoming cold water has no check valves. Only check valves in the system will be located inside the mixing valve on both the hot and cold side.Combat Veteran owned, Final Salute LLC on FaceBook & Twitter.
www.afinalsalute.com0 -
Will check valves in mixer increase expantion pressure in DHW tank?
Thanks
Thanks, I all ready put in an inline water pressure gauge so I know exactly what the pressure is all the time. How much fluctuation can the system make up for before I have to change the tank pressure? It's on city water.Combat Veteran owned, Final Salute LLC on FaceBook & Twitter.
The air charge will adapt with incoming small fluctuations in pressure. You should not need readjust air charge unless you're experiencing system problems or if the static pressure is increased. Maybe check pressure every 6 months or so depending on system flow rates. Just make sure you remove water pressure from tank before checking or adjusting the air charge. Hope this helps.-1
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
