Steam baseboard vent maintenance help
zigloo99
Member Posts: 5
I'm unsure what kind of vent this is for a baseboard in a 1-pipe steam system. It looks like this and I haven't been able to find anything similar looking online.
Have suggestions or equivalent vent products to suggest to use in this setup?
Show us the other end of the baseboard also, please.0
Unless I am sadly mistaken, that is a hygroscopic steam vent, similar to the Hoffman Model 508. I have no personal experience with them at all! But they are alleged to work -- and replacements are available on ebay, of all places.Br. Jamie, osb
It's an Maid of the Mist ...I have enough experience to know , that I dont know it all0
Drill a small hole in the cover and install a straight convector vent with a coupler and nipple. Those hydroscopic vents are junk.0
But you want an very slow vent .. It's an single pipe iron base board ... They should be installed two pipeI have enough experience to know , that I dont know it all0
That is an old Hoffman No. 500 steam vent, for both hot water and steam believe it or not. Just replace it with a straight Gorton vent.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......0 -
Definitely not a case where something will work well with two different kinds of heating system.0
I think I would try again the #500 or #508 ... Better then an HeatTimerI have enough experience to know , that I dont know it all0
Thanks! I'm going to try the #508, for now, to see how it works out as it's cheap to test with.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
