Cold radiator
Donkey_Dom
Member Posts: 1
I have a one pipe steam system. Everything to seems to work well - all rads heat up evenly, etc with exception of one radiator. This radiator was installed a couple of years ago from what appeared to be an abandoned pipe from a radiator removal before I had the house. The radiator is close to the boiler - I think the second branch- run about 12 feet or so on main floor. With no air vent the radiator heats up fully, quickly, and sends out a lot of steam in just a few minutes. However as soon as steam vent is put back on, radiator loses temp quickly and remains ice cold. I tried the varivalves fully open, and maid o mist with largest opening I could get (D)
Steam always finds the path of least resistance. What kind of main vent and what vents are on the other radiators?
3PSI gauge0
- 85.6K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
