Have to refill steam boiler once every two weeks
RomanGK_26986764589
Member Posts: 229
Hello everyone, I hope everyone is staying warm!
With the weather in teens these past 2 weeks here in NJ I realized that I have to add about a gallon to a gallon and a half of water to my Weil McLane EG 40 steam boiler every two weeks. Normally, during milder weather temps, I can last a month without adding any water. My radiator vents are all new and don't leak steam, no leaks in the pipes, and the pressure is low. The boiler does run a lot right now. I know some water does evaporate with each cycle, but a gallon in just two weeks.... ? Is it excessive?
If there are no obvious signs of a leak, anywhere, I would wait for the weather to get back in the normal range, maybe 30's, and see if the water consumption is more what you normally see. It's been really cold and boilers have run a lot. Hard to gauge unusual water consumption when we have such an extraordinary span of frigid weather.0
When you say you have to add water, is the LWCO shutting the boiler off or are you preemptively adding water?0
@Danny Scully I preemptively add water.0
As a matter of reference I've added a 1/2 gallon of water since October. Check your packing nuts on the valves, the union between the valve and rad, and the main vents.0
1 gallon or so every two weeks for a ~125 MBH boiler is fine. It's on the high side of normal but it's fine.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes1 -
@RomanGK_26986764589, my advise would be to stop adding water and wait until it actually goes off on low water.1
Quick update, the good news is I found a leak!
It is a radiator runout on the first floor bathroom. The bad news is that I will need to break up that tiled floor to get to it. I'll probably do it in spring or summer when I won't need the heat just in case something goes wrong.0 -
@Fred Yep. I fanatically check the sight glass at least a few times a week so that's why I don't even have an auto water feeder.
I eliminated a night setback until I fix the leak because it only seems to pronounce itself when the boiler hits 1.6 psi of pressure and cuts out during setbacks or during this extreme cold we had where the boiler would run a lot and hit that 1.6 psi quite often.
Also, a curious thing I noticed, I never had to add water to the boiler more than once a season. So now when I added water a couple of times due to a leak I noticed how calm my 0-3 psi gauge has become. I though the opposite would happen, i.e. more water I add more minerals I introduce to the boiler and water should boil more violently but, for some reason, the opposite happened. The gauge needle almost doesn't shake and is very precise. The sight glass water bounce also decreased from about 0.5 of an inch to about 0.25 of an inch. The trap itself with controls on it is clean and the pressuretrol does cut out at 1.6 psi and cuts back in at 0.7 psi. when coming back from a setback. Any ideas why adding water makes the boiling more stable?0
@RomanGK_26986764589 , I see the sight glass water level out to almost no bounce on the occasions where I add a little water but I have concluded that it is more likely that it is the result of a little cooling of the boiler water and a little less boiling action. I don't stand around long enough to watch things come back up to a full boil where I get about a half inch of bounce.0
- 85.6K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
