A picture tells it all
Zman
Member Posts: 7,569
Funny thing I came across today.
This was on the discharge of a "generously sized" pool pump.
Albert Einstein
Albert Einstein
Reminds me of Dan's story about the dead-headed pressure booster pump.All Steamed Up, Inc.
Consulting0 -
I love how right where it ballooned is the "NOT FOR PTESSURE" warning. How hot was the water at the pump discharge?Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
Good one. I'm on it!ratio said:@Erin Holohan Haskell, maybe we need a button for "****‽"
President
HeatingHelp.com1 -
I wouldn't have thought that foam core could have expanded that much.Bob Boan
The water is 86 degree pool water. It did this right before the pump cavitated and blew up the impeller. I suspect the sand filter plugged causing the inlet of the pump to go even more negative. It doesn't help that the pump is a couple feet above the pool and is located at 9,600 feet (atmospheric pressure ~ 10.xxpsi).Solid_Fuel_Man said:I love how right where it ballooned is the "NOT FOR PTESSURE" warning. How hot was the water at the pump discharge?
I like the idea of a **** category, I have lots of pictures.
You can tell folks not to use cellular core PVC all day, nothing like a picture...."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
No one could have the ability to dream that up for photoshoping that. A little steam action to heat the pipe.
Looks like a ruptured colon.......or a gastric bypass gone wrong.
I like the **** radio button! Please0 -
A pool running ar 9600' in late December? Where are you at?Bob Boan
Had a pump piped with PVC on a sand filter set up to filter water tower water. his thing had operated for 10 years with no issues.
The customer complained the pvc let go and flooded the place and someone went and fixed it. This system had air operated pneumatic valves on it that were normally closed
A month later I was on call and they called me on a Saturday with the same problem. Water all over the place.
Pvc looked like it got hot, softened and pulled the threaded adapter out of the pump.
I found out they had no compressed air so the valves were shut the pump had run ded headed and overheated the pvc.
They had recently installed new air compressors and controls and were now shutting down the compressors on weekends.
I installed a reverse acting pressure control on the air line and wired it to the pump so a loss of air pressure would shut down the pump0 -
Colorado Rockies.Ironman said:A pool running ar 9600' in late December? Where are you at?
They run it year round with no cover. It creates it's own weather system when it gets real cold."If you can't explain it simply, you don't understand it well enough"
Albert Einstein1 -
Heck they heat the streets, walks and parking lots in some of those Colorado resorts. Those 1%ers have no issue with that expense
Probably the more NG the resorts consume the richer those folk become?Bob "hot rod" Rohr
Does this mean the Zman is 1%er?hot rod said:Heck they heat the streets, walks and parking lots in some of those Colorado resorts. Those 1%ers have no issue with that expense
Bob Boan
You can choose to do what you want, but you cannot choose the consequences.1 -
- 85.6K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
