Slant/Fin Concept 21 boiler and purge problem
sloaner
Member Posts: 3
I have a Slant/Fin Concept 21 boiler installed in 2003 and regularly maintained. It has shut off with a flashing red LED indicating a problem with purge. There is also water leaking from near a valve atop the hot water tank; I hand-tightened this and the leak appears to have stopped. The user guide does not indicate how to troubleshoot this. Any advice?
Could be a bad inducer motor or something blocking the intake and or vent pipe.0
Intake vent is clear.0
Page 24 in the manual.0
The only manual I have is 4 pages long. Do you have a link to a more thorough one?0
Slant/Fin has two IOMs for the Concept 21 boilers. One is for the original control board where there is a clear plastic cover over the main control board. The other uses a control made by United Technologies. The error messages are different for each board. Please let Slant/Fin know which control your boiler has and we will send the correct IOM, we can email a pdf file copy.
Call 1 800 873 4346 and speak with someone in technical services.
We can also walk you thru the trouble shooting process.
Thank you,
Keith Muhlmeister
Slant/Fin Corporation2
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
