Steam pressurerol setting
Nycwrenchturn
Member Posts: 19
Everyone always says to set pressuretrol to 1.5 main and 1.0 subtractive differential . 99 percent of pressuretrols only go down to 2 .. is there an invisible setting ? If you put the screw down little below 2 are we at 1.5 or ??
Yeah, you have to sort of estimate where the 1.5 setting is. New pressuretrols have corrected this.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
Not all seem to like operating that low either. Some won’t reset or start back up reliably. You kind of have to try and watch them. Vaporstat and a 1-5lb gauge is an option.Just a guy running some pipes.0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
