Don't You Just Love 3-1/2" Supply Mains?
New England SteamWorks
Member Posts: 1,505
Another beautiful old Victorian. My comfort zone. But too much fresh water, and the old girl has sprung a leak:
newenglandsteamworks.com
And that old header has got to go. But she won't go quietly...
But it's 3-1/2". Fittings very difficult to source, insulation seemingly impossible.New England SteamWorks
newenglandsteamworks.com0 -
At least the meager vents are easy to access and upgrade...
Not.
You really should come to the place I care for, and take a look at the way @Charlie from wmass managed a big old header (actually the steam drum from a really ancient H.B. Smith). You'd be welcome, anytime!Br. Jamie, osb
I wish I could write my true experiences with this one, but it is a PG forum so I will demur...
That header put up such a struggle that although we succeeded in the end, seems hard to call it a victory.
Any trick to lining up old piping? I used them all, plus clamps, jacks, and prayers.
But we survived. Header is connected. Onward.
Did you hear (I am always a little behind) Glen Campbell died?
One of the greatest songs. Ever.
And yes, I can hijack my own thread...
newenglandsteamworks.com2 -
Being a @Charlie from wmass fan, and all things old and steam, I am certain I would enjoy that immensely and I will take you up on that offer. If you could message me with your address I'll contact you when I am traveling in that direction.New England SteamWorks
newenglandsteamworks.com1 -
Weil-McLain 3-80?All Steamed Up, Inc.
Consulting0 -
The boiler that heated our old shop was 3 1/2". Last time I checked (which was a while ago) you could get 3 1/2" pipe but no fittings.
I also ran into 7" once which I almost cut the flanges off with a torch to relocate them thinking it was 6" . Luckily I stopped in time and reworked things0 -
Almost there. She'll be running tomorrow. Money shot for @Sailah, whose vents arrived in the nick of time!
Why do you tease us with one picture!0
beautiful job @New England SteamWorks ..... i have a few steam systems that work on in nyc with 3.5 & 4.5 pipe and fittings....3.5 i see alotASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
Nice work! We can get 3 1/2 pipe and welded fittings. Anything over 2 inches, we weld.0
Strainers on your air vents. I see.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
What's the fitting between the strainers and the vents? A valve?0
Think it’s just a tee for additional vents @ratio0
Really nice @New England SteamWorks
@Paul48, I like the brass name plate idea. Trouble is the newer boilers don't last long enough to make it worthwhile0 -
I was thinking, having it on a small chain on the header. You should be able to sneak that out of the insulation, and that's where the craftsmanship exists.0
Sorry...Danny Scully said:Why do you tease us with one picture!
She's running now.
The owner is a terrific piano player, and her piano was directly above the boiler. Every day I was serenaded. Especially with this one. Ingrid Bergman. Sigh...
Yes, they are tees between the strainer and vents. Despite my best measuring and guesstimates, sometimes I have been off when I timed the steam, and I grew weary of rebuilding the antlers. So for the price of a tee and plug, I add redundancy. Now when I time them I can vent as needed. And of course, Peter approves wholeheartedly...
newenglandsteamworks.com5 -
They moth-balled the boiler many, many years ago when the water consumption shot up and after many frustrating attempts to find a suitable contractor to tackle the project. Most never came back! So they began to use wood and pellets for heat.
Then they found heatinghelp.com.
When the boiler finally fired and filled the radiators and home with central heat after so many years, the owners told me that they became flabbergasted (little did I know down in the basement skimming and insulating), and their thoughts turned immediately to Young Frankenstein. Too funny...New England SteamWorks
Gorgeous install as alway @New England SteamWorks-1
amazing when something works the way it's supposed to0
It is beaut @New England SteamWorksDL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......0 -
awesome.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
