water tank needs for radiant system
Gilly184
Gilly184 Member Posts: 2
edited August 2017 in THE MAIN WALL
Hello all. New to the wall. I recently installed a one room 600 sq foot radiant system of AL-Pex made up of three 200 ft loops. Now i am at the point of deciding on a heating element and understand every 100 ft of 1/2" is about 1gal volume,so i am wondering if i can get away with a 10-15 gal hot water tank with expansion tank, circulator pump and manifold? i believe the size of this system would work for a standard hot water tank vs a boiler... am i correct?
  • Zman
    Zman Member Posts: 7,561
    The whole process should start with a heat loss calculation of the space. That is how you figure out the boiler size.
    I would use a small modulating electric boiler and utilized outdoor reset to maximize comfort and efficiency.
    Electric water heaters are for heating domestic water. Boilers are designed for heating systems.
    Albert Einstein
    Ironman
  • Gilly184
    thank you for the response. I was told that with such a small system, that a boiler would short cycle regularly and would make the system inefficient and shorten the life cycle. i am assuming that they make very small boilers that would fit this system once i calculate the heat loss?
  • Zman
    Given the size of your system, I agree that it may not be a good fit for a gas burning boiler. Unless you have other heating needs, it will be expensive to install and will short cycle.
    Electric would work well for a small setup like that and yes they do make small modulating electric boilers.
    Albert Einstein
  • Henry
    Henry Member Posts: 998
    Thermolec makes small boilers with outdoor reset:
    thermolec.com/en/productView.aspx?type=product&id=58
  • Rich_49
    Rich_49 Member Posts: 2,766
    With all due respect Zman . We know nothing about the construction of this smaller area and it's needs/ requirements . The Purist in me agrees with you about boilers for heat and water heaters for domestic water . The other me which is always at odds with the Purist thinks boilers are required for high temp applications while a water heater is quite adequate for low temp / low load applications . An electric boiler is not really anything more than an electric water heater without mass , Aye ?
    For instance , this space could quite conceivably be 15,435 BTUh at design with a 25.6 BTU per sq ft requirement and maybe it only needs 125* water . Would you agree ? If this is so there is no reason why a single element 4,500 watt element tanked water heater could not readily perform the duty required of it . The codes are slow to respond thus the continued resistance to adopt other , better technology based on individual systems and lower load buildings . While building science technology advances rapidly we continue to sit on the sidelines with old ideas .
    To determine this though we are in agreement that a room by room heat loss is required to actually eliminate the generalization and have a real discussion about a source .
    In the meantime , everyone could purchase something like this
    https://www.uponorpro.com/~/media/extranet/files/heating literature/radiant ready 30e/rr30e_insg_h220_0411.ashx?version=050320110848&version=050320110848
    or any number of other well made and designed electric products
    732-751-1560
    Rich McGrath 732-581-3833
    Zman
  • Zman
    edited August 2017
    @Rich
    I absolutely agree. Thanks for the link to the Uphoner product. That is awesome!
    I almost made the water heater recommendation as it would likely be the right size. I guess I don't like to recommend electric water heaters because they have become the "go to" device for every knucklehead installer out there. I think the tiny foot print of the electric boiler is a real bonus.
    Albert Einstein
    HVACNUT
