1 take off 2 mains
SeanBeans
Member Posts: 520
When you guys get to a job and there is a T that is not bull headed do you guys break that tee and use 2 take offs off of the header?
Looking back at a job and it looks like the last guy unioned the 2 mains together..
Disadvantages to doing it that way?
Neither are counterflow0
Nobody wants to run anything bigger than 2". The mains should come out of the header separately.
When in doubt check the edr and size accordingly. the lower the steam velocity the better. But if a bunch of radiation has been removed............0
- 85.6K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
