Low Water Cutoff
dc07736
Member Posts: 15
Hi,
I am going to buy a new Low Water Cutoff - 24 volt
What would you suggest?
Have 100 year old system. Historic house in Kingston NY
20 cast iron radiators - one pipe system
Install used Burnham steam boiler 142,000 btu
Thank You
DC
Thank You
DC
Hyrdolevel safgard0
If you have a tapping in the boiler at the right location, a Safgard LWCO is a good option. If the boiler does not have a tapping in a location appropriate for the Safgard probe, the McDonnell Miller #67 LWCO is probably your best bet.0
- 109 Chimneys & Flues
- 975 Plumbing
- 386 Solar
- 17 Recall Announcements
