What to do with an old boiler's 2 Pressuretrolls, Safguard 400 water feeder, gauge glass, pigtails
cubicacres
Member Posts: 358
We have our old WMC EGH-85 boiler's 2 Honeywell pressuretrolls, pigtails, Safguard 400 water feeder, and gauge glass left form the boiler replacement last year. Do these have any value or use with our new WMC EG 75 boiler or would they be of use to someone else? Not sure if ebay, craiglsist, etc. is a place for them, or just the garbage.
Post them on the "buy, sell barter" here.
The safeguard is a valuable item for anyone who has the misfortune to have a "cycleguard".--NBC0 -
Be careful if the old pressure controls may contain a mercury switch0
The seem nearly identical (at least on the outside) to the new Honeywell pressuretrolls on our new boiler. I think they were from the old boiler initial install in the late 80s, then the block was replaced in the late 90s in the 10th year under warranty. Maybe a long history of rusting out in that basement boiler room? The old boiler was quite corroded. We're working on getting our fresh water intake under control by addressing the possible leaks on our new boiler.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
