Recognize This Air Vent?
Rusted & difficult to read, but would def like to replace with same size/exact model if possible...
Thanks fellas,
Gregg
I'd bet @Steamhead knows what it is.
Curious, why do you want to replace it with something the same size and exact model?
I think it says Hoffman Specialty 74 on the side .
You will need a bigger vent, maybe more than one. Try a big mouth from the store here.
what size are the mains which this handles?--NBC0 -
Answering ChrisJ, I'm going same size/model or similar so I don't screw it up, they probably sized it correctly.
Thanks Bob you're right about the Hoffman Specialty.
Nicholas, why do you think the system needs a bigger vent or multiple?
Thanks fellas,
GREGG0 -
Perhaps if it was originally coal fired it was correct, but I highly doubt it is enough venting with a modern boiler. You should measure the length and size of your mains and post it, we will be able to recommend how much venting you may need.BuildingOpsGregg said:Answering ChrisJ, I'm going same size/model or similar so I don't screw it up, they probably sized it correctly.
Thanks fellas,
GREGG0 -
Answering KC Jones:
Roger that, heading over now, will grab a tape and post more details, thanks KC!
-BuildingOpsGregg0 -
That's a Hoffman #74 vent. Not right for a Main vent anyway. The #74 is designed as a steam heater vent. The #75 is the correct vent for a main but it is probably way to small for the average Main.0
What's a "Steam heater vent" ???Fred said:That's a Hoffman #74 vent. Not right for a Main vent anyway. The #74 is designed as a steam heater vent. The #75 is the correct vent for a main but it is probably way to small for the average Main.
http://www.supplyhouse.com/Hoffman-401429-74-1-2-x-3-4-Straight-Steam-Unit-Heater-Air-Valve-11740000-p
Maybe think of a hanging fan forced steam coil/fins unit heater.0
Correct. What pressure does your system run?All Steamed Up, Inc.
Consulting0
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 959 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
