Picture loading
BobC
Member Posts: 5,476
@Erin Holohan Haskell Over the last 5 or 6 weeks I've noticed that posts with a number of pictures load and then the text jumps around as each picture loads, this makes reading a post harder than it should be because of all the jumping around. I've noticed on both my computers using Firefox.
Anybody else having this problem?
Bob
Bob
3PSI gauge
3PSI gauge
I see the same thing here. It's most obvious on threads with a lot of images in multiple posts.
I'm guessing this may caused by a coding decision to load full resolution images inline, rather than storing scaled-down versions and displaying those in the HTML.0 -
Thanks for the heads up. We'll look into this.President
HeatingHelp.com0 -
Valuable feedback and thoughts, guys. Thanks!Retired and loving it.0
Yes, thanks very much!
Our tech team agrees that this is the result of large images taking longer to load than the rest of the page. So let's try to keep images sized for Web. Thanks!President
HeatingHelp.com0 -
The problem is almost any camera generates a huge file because it's a lot cheaper to supply a 20MB sensor (usually noisy and somewhat fuzzy) than a decent lens. It is unrealistic to expect people to create a small image file for a site
Why can't we go back to the thumbnail that doesn't expand till you click on it. That worked well for years.
3PSI gauge1 -
That's a workaround, of course -- but having access to full resolution photos is often quite valuable. Is there some reason Vanilla can not scale them for inline (preview) display? Remember that not so many years ago, "sized for the web" meant 800x600 (and at one time it was 320x240.)0
Some of the other boards I'm on don't even let you post a pic that large. The smallest allowed size on these is 650x650.
On here, I try to reduce mine before posting to no more than 800x600. That's plenty big enough for the Web. Compare my postings to some of those that take forever to load and you'll see the difference.All Steamed Up, Inc.
Consulting0 -
Here's what Firefox sees -- note the original dimensions and scaling (which is being done in the browser, so it has to load the entire image before displaying):
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 879 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
