Making the best with less than perfect
PaulVW
Member Posts: 2
We will be replacing a boiler with 2 high efficiency boilers because of how the mechanical room is piped, we can't change the 9 zone pumps to pump away from the expansion tank. The pumps will be on the return to a 3" hydrolic separator. Normally I connect the expansion tank on or near the hydro-separator. I'm wondering if in this case it would be preferable to install it on the boiler side of the hydro-separator? All the pumps are fairly low head and the zone pipes are good sized so I don't anticipate any problems with cavitation or air removal as the existing system worked reasonably well for many years. Would like some ideas to make the best of a less than perfect situation.
Starting with the near-kilowatt load of all those circulators...0
What about changing the pumps to zone valves and then use an ECM system circ?
It is not recommended pumping into the return on a sep or primary secondary piping.
With multiple boilers and large piping, if the system requires a base mounted expansion tank, of example, you can connect the tank like this.
Living the hydronic dream2
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
