Boiler chemicals
RomanP
Member Posts: 102
Hey there, gents
I'd like to pick your brains on subject of boiler water treatment chemicals. When performing a annual maintenance, which are the good chemicals to use? Steam and hot water boilers.
Thanks so much!
Thanks so much!
Best to test the fluid to see if any treatment is required. The boiler manufacturers are getting pretty adamant about fluid quality. I think you will see more and more warranty refusals when water quality does not meet their requirements
Ph and TDS are good numbers to know. Either treat the water, or fill the systems with DI water
It's a three step process, clean the system with a hydronic "detergent". Fill with DI water, Add inhibitors for best protection
Test the fluid every few years. If you have non barrier radiant tube for example, you may need an ongoing chemical regimentBob "hot rod" Rohr
My plumber did not put any treatment. He said my water PH was fine.0
Tell us more about your boiler, system and what the history is....0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
