Our latest creation
Nice job, I'm sure they will enjoy the fuel savings.
3PSI gauge0 -
Beautiful work.
But boy do those 2" risers look tiny on an IN9, eh?
Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
yes, they do..but it seems to work for their boilers so i guess they figure why argue with success..ChrisJ said:Beautiful work.
But boy do those 2" risers look tiny on an IN9, eh?gwgillplumbingandheating.com
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.1 -
I'm sure this will work as good as it looks- beautifully.All Steamed Up, Inc.
Consulting0 -
I'm betting he uses very little tape and dope, so none ends up in the exposed threads. Also, I *think* cast iron fittings don't usually show teeth marks like malleable. Never paid attention honestly, but that's my guess.rick in Alaska said:Two questions: how do you keep the pipe dope cleaned off after threading in to the fittings, and what do you use for a pipe wrench to not mark the fittings up?
Nice clean looking job.
Rick
actually i do use alot of blue monster thread tape covered in megaloc pipe thread dope. But my personal pet peeve is seeing pipe thread compound on a completed install. Since i was on this job myself, i figured i would lead by example and spent about two hours with a razor blade and a wire brush. I know...its anal..but its a personal psychological issue..i don't enforce it with the guys, but i figure if they watch me doing it, it may rub off...maybe..as for pipe wrenches, we just use standard wrenches..we take them off to reposition, we don't ratchet them..maybe thats why the marks are minimal.rick in Alaska said:Two questions: how do you keep the pipe dope cleaned off after threading in to the fittings, and what do you use for a pipe wrench to not mark the fittings up?
Rickgwgillplumbingandheating.com
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.2 -
Beautiful Job. I love it!0
Looks great.....Which I expected nothing less! What's that pipe near the wall that looks like a false water line, but reversed.To learn more about this professional, click here to visit their ad in Find A Contractor.0
That is a false water line. The vent doesn't matter where it is placed as long as its on the top, as its function is just to provide a siphon break so one doesn't get the effect of a 'bucket flush' on a toilet during the initial cold start up heavy condensate load. This is a vapor system, and on vapor systems we run the siphon break pipe up to the ceiling as an open pipe, (no air vent needed).The Steam Whisperer said:Looks great.....Which I expected nothing less! What's that pipe near the wall that looks like a false water line, but reversed.
So there is no balance pipe connected to the system side of the loop to equalize pressure on the return? It looks like you are just using the stacked water in the pipe to equalize the pressure on the end of the return.....I 've done that before.To learn more about this professional, click here to visit their ad in Find A Contractor.0
Correct. Hows the steam business in Chicago these days?gwgillplumbingandheating.com
Is that water feed in gal?0
yes, gallons..hydrolevel vxt-24gwgillplumbingandheating.com
Is that old Vaporstat off the old boiler? Is it more accurate than the new ones?0
Doing pretty well. Looking at some pretty big projects over the next couple years and growing repeat business. Making a big ad push to expand up in the North Shore.... hope it pays off. Running ads in Ravinia, Angie's List and the Merc. magazine. Found out that Yelp is a waste of money...thier categories are too generic so you end up paying for a whole bunch of hits that are not in your field. With Yelp you pay by the Click...big waste of money. Beginning to break into the bigger high rise market on LSD, so that is promising and requires a lot of extra labor time due to lack of on site parking.To learn more about this professional, click here to visit their ad in Find A Contractor.1
No I meant is the piping galvanized lol0
Real nice job!0
You, sir, are a steely-eyed steam man!
Liking the old old style vaporstat. If they are off, do you try to adjust them?
Like the use of the 1/2" stainless piping around the vxt.
Interesting that stainless is now cheaper than brass in many cases, now that brass is no longer a "Californian killer".All Steamed Up, Inc.
https://heatinghelp.com/find-a-contractor/detail/all-steamed-up-inc1 -
lol..i'm sorry Danny- i had a brain traf..we started doing these feeders in stainless as Gordo picked up on when Steve determined that the feeders were significantly more stable when piped with ridgid pipe..but we didn't want to use black for it..i guess its kind of obvious in retrospect..now i wonder why we ever piped them directly with copper..i guess another brain trafDanny Scully said:No I meant is the piping galvanized lol
Hi Gordo- yes i will tinker with the vaporstats. Especially the new ones which tend to not work. I figure if they aren't working i have nothing to loss by employing the 'what happens if i turn this screw ' principal..lol..Gordo said:You, sir, are a steely-eyed steam man!
Interesting that stainless is now cheaper than brass in many cases, now that brass is no longer a "Californian killer".gwgillplumbingandheating.com
Hi KC- yes, that old vaporstat is off the old boiler. We will reuse a mercury switch everytime as the new units suck...er..i mean need more R&DKC_Jones said:Is that old Vaporstat off the old boiler? Is it more accurate than the new ones?
Wow. Exceptional work. It seems almost as if you've done this sort of thing before.terry0
Around here, 304SS nipples and fittings sell for just under half the price of LF brass.Gordo said:Interesting that stainless is now cheaper than brass in many cases
Side note: There appear to be benefits from using both tape and dope on threaded SS-SS connections. SS-brass, SS-steel, and SS-copper all work pretty well with either or IME.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
