Triangle Tube Propane Smell - Need Ideas - Please help!
I took the cover off so I could identify where the smell was coming from, and it seems to be coming from this pvc vent inside that the manual has labeled NTC Sensor. At this point I'm am completely beside myself why this is happening and would greatly appreciate any and all ideas this great forum could offer.
What does the vent piping outside look like?
It could be when the boiler is in low fire you get cross contamination/ reversion....
That would be the exhaust is being sucked back I the intake.0 -
I'll take a picture of the venting tomorrow when it's light out. However, based on manual it looks textbook.0
Wind can make textbooks not make sense . Check the location in the textbook and if it is near an inside corner or if something is blocking the exhaust . Wind blowing across the 2 just so can bring exhaust right into the intake's path .You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38331 -
I am going to guess right now it is a Concentric vent termination.... NOT a fan of these....aka they suck. Literally.
I have seen way too many issues w/ cross contamination.0 -
A gas valve that is not closing completely would probably give you a propane smell in that location. Is it more noticeable when the boiler is running or off."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Are you experiencing rough ignitions (whuump!) as well? There is a service bulletin for these -- you have the MCBA control which may be affected.0
By chance does it fog horn at all? The venturi's go bad quite often with cross contamination or just over time the plastic gets brittle.Tom
Montpelier Vt0 -
It's only when the boiler is running. It's been really bad these last few days. As far as the "Whummp" sound, I do get that on ignitions, but it's not terrible sounding, more like a normal sounding ignition. And sense you mention it Tom, the old owners complained of a "fog horn" noise coming from the boiler, but I haven't heard it yet.
Is there something "DIY" that I can do to get closer to the diagnosing the issue?0 -
Pull off that plastic tube where you smell the propane coming from and look inside the piece it's connected to. Do this of course with unit off! You should see whats in this pic.
Should be smooth and solid not cracked or fatigued. Also it shouldn't have a bunch of black soot.
Tom
Montpelier Vt0 -
Is it possible get a picture of the termination outside?0
Does the plastic part come off pretty easy?Tom said:Pull off that plastic tube where you smell the propane coming from and look inside the piece it's connected to. Do this of course with unit off! You should see whats in this pic.
Should be smooth and solid not cracked or fatigued. Also it shouldn't have a bunch of black soot.0 -
I find it odd they put a Tee Wye there instead of a regular 90 on the intake.
The white pipe should just pop off. Its just on there by friction.
Not sure either, but the venting supplement manual does show the Tee Wye as an option.0
The Vent Supplement copy I have here shows a couple of options for tees on vent terminations, but the only tee they show for a combustion air inlet is at the end of a vertical run.
Please understand: I'm not suggesting that this is the cause of your problem, or even that it's an unsafe condition. It's just not shown in the book.1 -
As kcopp said, the white pipe internally in the boiler just pops off its held by friction. Did you get a chance to look at it?Tom
Montpelier Vt0 -
Sorry, took so long to check..Had some medical issues end of last year so got distracted. But it looks okay to me. What do you think?Tom said:As kcopp said, the white pipe internally in the boiler just pops off its held by friction. Did you get a chance to look at it?
Its been a while since I looked inside a TT prestige.... that being said. I think something is missing. The intake pipe should be run into that hole.0
It does, i took it off to show that o-ring. You'd have to read the entire thread to see why I did so. Trying to identify the cause of a propane smell that happens once or twice a year. I was told to check for cracks on that ring.kcopp said:Its been a while since I looked inside a TT prestige.... that being said. I think something is missing. The intake pipe should be run into that hole.
Nothing unusual in the picture.
Have you checked the unions on the gas line. I have seen those leak on several occasions. Usually just takes a little tightening."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Yes, they are just fine.. Only happens once or twice a winter, usually when it's very cold. I identified where the smell is coming from, and it's the pvc terminal inside the unit.Zman said:Nothing unusual in the picture.
Have you checked the unions on the gas line. I have seen those leak on several occasions. Usually just takes a little tightening.0 -
Have the combustion tested again. If combustion is poor, you can get a smell like unburned gas. This comes from aldehydes, and if you have aldehydes you also have high levels of Carbon Monoxide.All Steamed Up, Inc.
Consulting1 -
Thanks for the tip. I had it re-piped a year ago, and they spent almost a half hour getting the gas/air mix exactly to manufacturer specs. The smell only happens 2 or 3 times a season. Very unpredictable.Steamhead said:Have the combustion tested again. If combustion is poor, you can get a smell like unburned gas. This comes from aldehydes, and if you have aldehydes you also have high levels of Carbon Monoxide.
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
